icanon's avatar
icanon
Part 2 Need help in buying a meter.
First let me say thanks to everyone who replied in my previous thread 'Need help in buying a meter. So yesterday I bought a multimeter.
As some of you may remember a neighbour of mine gave me a brand new still in the box 40W solar panel.
Here is the specs of the 40W solar panel.
Up to 40Watts
Open circuit volt. 21.5v
Max power volts. 17.1v
Short circuit current. 2.3A
Today a few minutes ago 'noon time' I tested my solar panel and here is what I got.
Volts: 10.07 Amps: 1.68
Question: Does this sound right? Is the volts/amps enough to change a 12v battery?
Thanks
  • icanon wrote:
    I connected the multimeter probes directly to the controller output, is that correct?
    Solar panels don't have controllers on them. If you mean that box on the back, that's simply a junction.
    I agree, it sounds like a defective panel, provided your meter was set to the proper DC voltage range.
  • Ok? Question on my process. I connected the multimeter probes directly to the controller output, is that correct?
    Will try again tomorrow got some errands to do.
    Thanks again for the replies.
  • Try aiming directly at the sun, mid day, when measuring. You should meter 17 to 21V and the Amperage sounds a bit light, should be seeing over 2 amps, if your battery is low in state of charge.
    Try again, in direct sunlight, mid day, around noon, and get back to us.
    In the future, get in the habit of listing the number first, then the unit of measure.
  • Nope. You need at least 13.5VDC to charge a battery. Sounds like your free by has some bad cells.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
