precioustime's avatar
precioustime
Explorer II
Sep 16, 2013
Patching a PPO rubber roof?
A small diameter area about 6" needs patching on a rubber roof.I heard of Dicor Patch. Any good? Will it be noticeable? Will it last long? An alternative would be to replace the complete roof with a new rubber material but that is very expensive. And disadvantages to that procedure? The area that needs covering is very small.
Moved to Tech Issues forum from DIY.
  • dbbls wrote:
    TPO is EPDM material with a coating on to prevent black streaks.
    Totally incorrect according to the Whole Building Design Guide which is the resource used by architects.
    "Thermoplastic polyolefin (TPO)
    TPO is the latest thermoplastic membrane introduced into the marketplace....It is formulated from polypropylene, polyethylene or other olefinic materials...."
    "Ethylene propylene diene monomer or terpolymer (EPDM):
    EPDM is a synthetic rubber sheet...."
    TPO seams are heat welded, EPDM seams are taped or glued. They are different materials. TPO is more expensive and a superior product.
  • I run a rubber roof for years, just carried a 4" roll of eternabond w/ me.
    IMO, there would never be a reason to replace a rubber roof,....not as long as a 12" and 24" roll of eternabond is available.
  • beemerphile1 wrote:
    Eternabond tape will take care of it.
    What is a PPO rubber roof? There is TPO which is more like vinyl and EPDM which is rubber.
  • Eternabond tape will take care of it.
  • I put a dicor patch on the roof in 2004. It was still on and in good shape in 2012 when I traded the trailer.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
