Mel B. wrote:
Yes I allready looked that up, That's not what I want on my RV. I just want to be able to have a portable Sat. Ant. and watch different channels in the living room and bed room. ...
Mel
No I am not upset, in fact, I empathize with your situation.
1. If you
must be able to watch different channels on the second TV, then you
must have two LNBs.
You have rejected the Trav'ler either for cost or not portable.
2. Is there another multi LNB solution? Yes, portable but not automatic. Proposed by Dutch_12078. Do you reject this because it is not automatic?
If yes, then the only way to watch any two channels is with two single LNB antennae as I suggested. The automatic and portable antennae, namely Tailgater and X2 have only one LNB. Do you also reject that suggestion?
3. Because, if you
must have only one receiver, then you only get one receiver per antenna.
Well, no solution, now what?
HTH;
John
