pirlbeck's avatar
pirlbeck
PD 9200 remote pendant-blind install help needed
I am trying to plug the remote pendant into the side of my 9200. This is in a truck camper and things are pretty tight, but if I knew for sure how the plug was orientated I am pretty sure I could get it plugged in with a long needle nose. Anyone have access to the side of one of these converters that could tell me which direction the locking tab goes? Pulling the converter would require removal of the 12V fuse panel and I would like to avoid that if possible.
Thanks!
  • lonekazoo wrote:
    Be mindful of where you mount the pendant. The flashing LED can get pretty annoying at night.
    Yep, good point. I mounted it inside the cabinet next to the converter, that way if I want to see what it is doing I have to open the cabinet door.
  • Be mindful of where you mount the pendant. The flashing LED can get pretty annoying at night.
  • OK thanks for all the help. I will try it with the tab down. I tried looking at it with a mirror and a bore-a-scope, just not enough room on the side.
  • RoyB's avatar
    RoyB
    Explorer III
    Photo from google search for the PD9260 COnverter showing the pendant connector...
    Roy Ken
  • Try a small mirror and flashlight. Mine was tab down.
