cruz-in's avatar
cruz-in
Penguin I I Heatpump questions
Hi All.
Considering replacing our poor performing AC with a Penguin I I Heatpump. I have a few questions maybe you all can help me with
1) Dometic lists sizes as 13500 or "High Capacity" model. How many BTUs is the High Capacity model? Have searched and no one says...
2) Dometic brochure says it operates in heat mode to 30 degrees? Some websites say 40degrees. Anyone know which is correct.?
3) When used with a ducted system, it can be paired with the "Quick cool return air system." Is this similar to the Coleman "chill grill" allowing the dumping of cool air directly into the Rv bypassing the ducts?
Thanks in advance for the help.
  • Heat pumps should be able to work down to about 20F outdoor coil temperature, and will still not build up a significant amount of frost or ice on the coils.
    Manufactures are chicken, and set the thermostats around 40F to be safe with their warranties! And if there where to be ice collection on a outdoor coil, it might prevent the outdoor fan from running on a really cold day, thus prevent the electric heater from working properly.
    (that comes into effect more with PTAC air conditioners like used in Hotels and I have 97 of them at my retirement center! I could only wish the PTAC would spend more time in the heat pump mode rather than the energy consuming electric heat mode. It takes 3 times as much electric to run a electric heater than a heat pump.
    My guess is that manufactures try to change over to the furnace at around 40F temperature at the sensor inside the outdoor unit, that is near where the discharge air is located, so it can be cooler than the actual outside air temp, as the heat pump is discharging air that is about 15F cooler than the air going into it.
    Fred.
  • I've never seen any of them work below 40. I haven't thought of it until now but fooling it with an alternate heat source seems feasible. What to you think?
  • The Hi capacity is higher than a 13.5, but Dometic will NOT state it is 15k. IMO, it IS 15k or slightly below it.
    The operational is variable. Most will kick out at 30 to 36 degrees. Remember, the ambient sensor that causes this is mounted on the outside under the cover, so the actual temp may be a few degrees cooler. The rule is it will NOT operate below 35 degrees.
    The Quick Cool is the same thing as the RVP system. Doug
