RJsfishin
Oct 18, 2014Explorer
If you use Flair/it fittings, you won't ever have leaks. there is no O-rings or washers or anything else that can leak, there is nothing but the fitting itself, and the pex tubing, no tools, no nothing else. They are found at every RV supply, and many hardware stores. And they are not expensive in comparison.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
