hybrid_dw's avatar
hybrid_dw
PEX pipe and fittings
Starcraft Antigua 2005, Water manifold made of PEX and those one-time crimp hose clamps leak. See pics below. the black plastic PEX "T" somehow cracked on a diagonal across the intersection and streams water. I go to Home Depot and match the same size PEX "T" with a PEX brass "T". I decide to use "real" hose clamps, you know the worm type adjustable screw so that I can re-use, relocate adjust, etc. Now all three locations where the PEX is clamped over the pipe onto the fitting leak. I have them cranked down beyond tight. WTH? I imagine I should replace the whole manifold due to age but what works best here? Any help?
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
