hybrid_dw's avatar
hybrid_dw
PEX pipe and fittings
Starcraft Antigua 2005, Water manifold made of PEX and those one-time crimp hose clamps leak. See pics below. the black plastic PEX "T" somehow cracked on a diagonal across the intersection and streams water. I go to Home Depot and match the same size PEX "T" with a PEX brass "T". I decide to use "real" hose clamps, you know the worm type adjustable screw so that I can re-use, relocate adjust, etc. Now all three locations where the PEX is clamped over the pipe onto the fitting leak. I have them cranked down beyond tight. WTH? I imagine I should replace the whole manifold due to age but what works best here? Any help?
  • I don't think you're supposed to re-use pex that's been crimped and then un-crimped. I never have, but luckily my location is very easy to get at.
    My vote is replace all the short pieces that are involved with leaks. Also the crimp connectors are going to be tighter than a hose clamp, which are designed to clamp softer rubber-like material hoses. JMHO
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
