SoundGuy
Apr 16, 2018Explorer
crazyro wrote:
Could the electric brakes somehow have been triggered? Or is it a more simple answer and I just need a new battery?
Trailer brakes have nothing to do with the trailer battery other than when the break away switch lanyard has been pulled so assuming that's not the case it sounds like the battery could be pooched. Never is everything completely off as your propane detector is always powered, so too is a radio memory circuit unless you've installed a kill switch, as well as a fridge climate control circuit unless you've also made sure to turn it off. You haven't told us anything about the battery, particularly type and age, so maybe it's simply had enough of this life. ;)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
