theoldwizard1
Apr 17, 2018Explorer II
azrving wrote:
Fuse buddy can be used on individual circuits
Fuse buddy is not a bad tool but just not required in this case.
Most modern fuse panels use "plug in" automotive fuses. These are fairly accurate "resistors", so by measuring the voltage drop across the fuse you can see how much each circuit is drawing ! There are a lot of videos on how to do this. Here is one :
The BEST Way TO Perform a Parasitic Draw Test
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
