1995
you pssibly have what is called a 'tell tail' ?
it is the automatic LP cut off controller
it will be in the kitchen area near the floor
has a little on/off switch a light/led and a beeper
make sure it is off
then go outside and close the LP tank main valve aka LP OFF
go back inside turn the tel tell on, it should beep at you
go outside and 'SLOWLY' open the lp tank main valve
in a couple of minutes the tel ell should blink green
when it does you have LP to the appliances
and they should work when you turn their switches on
it could take a few seconds for the 'air' to bleed out of the lines and the LP to get to the appliance burner, the applince to start
fridge and water have a switch to turn them on
cook stove probably has a push button striker for the burners
pilot for the oven
