Gjac
Aug 12, 2014Explorer III
rockhillmanor wrote:Thanks for the explanation, but in my case the sewer hose is encased in a thermoplastic semi circular housing under the wet bay compartment I slide it out to dump and back in to store. It never lays on the ground and I just slide out enough hose to reach the dump hole. I never remove have to remove it except to replace it. I don't know what other MFG's have this set up but I really like it.Gjac wrote:
I guess everyone thinks differently on this forum which is good. Myself I would rather replace mine with a new one from Walmart every 5 years due to pin holes or rusted springs than buy one for 4 times the price that will last 10 years, unless someone steps on it. They start to smell after several years anyway. Mine is encapsulated in a plastic housing and does not get disconnected except when I change it.
It is NOT just that it lasts longer.
I too dug my heels in thinking I was not going to buy some new dodad sewer hose either. IMHO a sewer hose was a sewer hose.
Then I helped an elderly couple at a CG unhook their Rhino sewer hose and put it away for them because the husband was not feeling well.
WHAT A DIFFERENCE! After 6 years of handling/trying to jam that cheap stinky slinky that comes with your MH and then handling that Rhino hose just once was all it took. I ran out and bought one that day.
I could not believe how just changing to the Rhino made hooking, unhooking up to the sewer and storage SO much easier.
The key feature is that it "collapses" any where in the line you want so for short runs you don't have a full length of slinky winding all over you site to the sewer hookup. You are in control of just how much sewer hose you need. Then collapse it all the way to fit in one corner of your bay flat instead of a balled up slinky that won't stay put after you put it in.
And their connections and extension are IMHO the best around. When you buy the Rhino it also INCLUDES all the connectors you are going to eventually have to buy when required by CG's.
I use the sewer connection ALL the time whether it is required or not. Wish everybody did. It eliminates all the sewer smell that comes out when you just shove a hose down it without a connector.
Sorry for pushing the Rhino I just wished I didn't wait so long to get sewer hose smart! Sure made my RV'ing experience a whole lot nicer!:B
