Bumpyroad
Aug 14, 2014Explorer
PawPaw_n_Gram wrote:
Another thing with macerators is the heavy weight hanging off the end of the outlet pipe and vibration from the motor running can cause either the outlet pipe or the macerator connectors to break.
if this is an issue, you can easily just use a foot of a good stinky slinky to bridge between outlet pipe and the macerator to take the vibration.
and as far as the excessive water use of a sewer solution, those who backflush filling the tank up three times using a clear elbow probably use as much if not more.
bumpy
