Jovannin's avatar
Jovannin
Pipes Make Growling/Farting Noise At Start of Toilet Flush
We are having a plumbing noise issue for which we can’t seem to find any information or solution ideas. Hope one of you can help us out.
We have a 2008 travel trailer (Fun Finder X210) that we purchased in June. The toilet is a relatively new Dometic 310 — sticker says it was manufactured in August 2020. When we push the pedal down to flush, there is a very loud groaning/farting (raspberry!) sound coming from inside the wall. If you hold the pedal down long enough (5-10 seconds), the pitch of the sound gradually gets lower until it finally stops altogether while the toilet keeps flushing silently. If you don’t flush the toilet long enough for the noise to stop, you get the noise again for about 1-2 seconds if you flush again right away. But if you hold the flush long enough to allow the noise to stop, and then flush it again right away, there’s only a brief half-second of the noise during the flush. The noise always happens at least briefly.
The noise is worst when the toilet has been unused for a while. Not sure if there is any connection, but it also takes about 3 seconds for there to be a good flow of water into the toilet bowl. That resolves pretty much in tandem with the noise resolving.
For what it’s worth, the noise only happens when using the toilet, and it does not happen when we run water from the sink or tub taps. It happens regardless of the water source (pump and city water alike).
My husband is a very handy guy, comfortable with plumbing … but the particulars of RV plumbing are new to him. If someone can point us to exactly what we need to replace or fix, he can definitely do it. Is it a valve of some sort? Is it the vacuum breaker? Could it be the inlet on the water valve — maybe a blocked screen?
Thanks in advance!
  • Beats the c r a p out of me.
    Seriously though I would think a restricted water line is the culprit or the roof vent for the blank tank may be blocked or partially blocked.
    Normally the sound you refer to would indicate a full black tank but the slow fill/flush makes me wonder.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
