Ski_Pro_3
Jun 18, 2019Explorer
No. Here's why;
The odds of you getting bad power that is so bad it damages something on a camper is pretty small. After all, what works on the camper that is AC powered? Not your stove, water pump or hot water. If you have an air conditioner AND it's hot outside, then maybe that, but otherwise nothing really.
I've never used one and never will on a camper I own. It's easy enough to work on and if anything ever did get damaged by some bad power, I'd fix it and probably for a lot less than that 'protector' costs.
If you need it for your computer gear as you elude to, get a UPS from Costco for around $60. It will convert the AC mains to DC and keep a battery charged. This battery will use an inverter to make AC again, isolating the AC mains from your computer gear.
But even that I wouldn't bother with, just get a surge protector power strip for under $30.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
