Gdetrailer
Oct 10, 2020Explorer III
Yes one pair of GC2 golf cart batteries WILL give you more Ahr capacity than two group 27.
Group 27 will give you at best 80Ahr each so a pair of group 27 gives you max of 160 Ahr. However, that 80Ahr is if you ran them 100% flat.. Which will kill the capacity in a matter of a couple cycles. Basically, you would only want to take a max of 20% out of group 27 and with two that means you get 32Ahr to work with.
The lowest rated GC2s would be 210Ahr and with GC2s you can easily extract 50% of the capacity and not harm the battery so you could easily use 105 Ahr.. GC2s can also be drawn even lower than 50%, you can extract up to 80% which is what the manufacturers use to rate the amount of charge/discharge cycles at..
Don't do that to group 27s..
And yes, I use one pair of GC2s to power my home fridge conversion, I have no issue going 24 hrs without the need of recharging. Add some solar panels and I could easily make a long weekend without the need to run a gen.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
