theoldwizard1
Oct 11, 2020Explorer II
mrad wrote:
... this forum has convinced me to go the golf cart battery route. At this time I hope to go with at least two golf cart batteries and if room allows, have them hook up four.
NOCO does make a battery box that hold TWO 6V golf cart batteries. HM426. These are NOT designed for interior mounting.
mrad wrote:
From what I understand, the two golf cart batteries should give me more amp hours than two group 27's???
Is there a big difference in brand quality on golf cart batteries? Or all they all better than 12 volt deep cycles?
Yes, more power with the GC2 batteries.
Trojan batteries are considered some of the best, but boy do you pay a lot for them. Interstate from Costco or Duracell from Sam's Club is the "best bang for the buck" !
mrad wrote:
Once they are fully charged, would the 2200 be able to supply enough power to keep fridge and batteries charged for the day?
Once you have topped off your batteries in the AM, 2 golf cart batteries should carry you through until early evening. Top off again. Probably less than 1 hour of run time.
mrad wrote:
I also have a champion 3100 I could use and may to keep one ac running during the day and then fire the onan up later in the afternoon so both can keep it cool for sleeping.
3 different generators to choose from ?
If you only have 1 A/C, your Champion should be able to run it AND charge your batteries. If you have 2 A/C units, time to fire up the Onan !
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
