enblethen
Aug 03, 2014Nomad
Welcome to rv.net!
Odds are that it should be a GFCI receptacle. The third wire should be bare, but someone might have put tape on it.
If you have a 120 volt test light or a meter, check the wires to see if they are hot, then trip the GFCI in the bath.
Outside should be either a GFCI or fed from GFCI.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
