BFL13
Oct 31, 2017Explorer II
Please Remind Me--AGMs to Full by Ammeter Action?
Probably LY, maybe Mex, but there was something about the way an AGM will initially be seen to get to Full by getting to lowest amps at a voltage--say 14.8v (charging spec for my AGMs) then --this is where I can't remember the post(s) on this---amps can rise again?
I finally got an ammeter (Trimetric) on my two 100ah AGMs in parallel during a recharge and they worked their way up to 14.8 then after a while, amps tapered down to about 0.9 for the pair.
I turned the voltage down to 13.7 for the night and this morning (at 0.01 amp at 13.7 for the pair) turned it back to 14.8 to see if amps would drop to zero like Phil gets as his idea of Full. (Only he does that with 13.8) So amps were back up to 0.9 again at the higher voltage, but later I noticed 1.0 and then 1.1 so amps were rising slowly. Same voltage.
I remember something was posted about that and what it all means, or at least I think I remember something about that :)
Anybody know about this? Thanks.
