LingerLonger's avatar
LingerLonger
Pleasure Way 2020 rekon
Touch screen control panel showing a fault:  "The DC Current Monitor is offline".  Any recommendations on a remedy.  Thank you
  • Max1's avatar
    Max1
    Explorer II
    Sounds like a glitch with your DC current monitor. First, try the basics: check all connections and fuses to make sure nothing’s loose or blown. If that doesn’t work, a system reset might help, turn off the power for a few minutes, then restart. If the issue persists, it could be a faulty sensor or control panel, and you might need to consult your manual or reach out to Pleasure Way’s customer support.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
