LindaV1's avatar
LindaV1
Plugged in but ac won't work without generater running
I am plugged into 30 amp shore power. My lights, stove fan, etc works but the air conditioner and the television will not come on unless I start my generator. The batteries show a full charge on the panel. What am I doing wrong?
  • Sounds like issue might be with your 'transfer switch'
    The transfer switch swaps AC power from shore or generator to feed main AC panel
    No AC from shore...OK from Gen---transfer switch stuck on generator input
    Bad relays/burnt contacts etc.
  • It would help if you filled in your profile so we know what you have.
    Have you checked your breakers?
  • Get a multimeter from Ace or similar hardware store and test the connections at the pedestal. All the items you listed could be DC powered and you don't really have AC available.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
