- MrWizardModeratorglad you got it going
- LindaV1ExplorerJust tested my connection and reconnected both ends. Everything is working now. Did not look like it was not making contact but it must not have been. Thanks to everyone who responded
- MrWizardModeratorIn a unit of that type with a 30 amp service
It might be behind the circuit breaker box
But it could be hidden anywhere
I hope somebody who had One can tell you where is at
dougrainer
Or Chris Bryant
Might know, hope they see this
But if you have the books and papers, try calling coachman the builder
And ask them where it is located - LindaV1ExplorerI have a 2007 Coach House 221xl Platinum
- Dennis12ExplorerI agree, it sounds like your seeing things run off of the battery's and the shore power is not getting to your coach. Plug something into where you have your shore power plugged and see if you have power to that point and if so go to the other end of your cord going into the coach and check there. If you do its probably the automatic transfer switch" like the wizard said.
- j-dExplorer IIWe really need to know he RV and setup you're asking about!
For example, neighbor had a 33-ft Class A, two A/C units, 5500-watt generator, and 30-amp shore tie service. By design, it would run only one A/C on shore tie, but both on generator... - ADAD437Explorerif you are truly getting power from the pedastle then it is likely the transfer switch, had one go bad on me once and the mnfg told me it defalts to gen side. they sent me a new board and all is well.
- ricklord2001ExplorerI had the exact same thing twice. Once it was the cord wasn't firmly plugged in and not making good contact. At that time I had an rv that I had to plug into the pedestal and the rv, the rv side wasn't making good contact. I disconnected both side and firmly reset them everything worked. Second time the pedestal breaker was bad. Good luck
- ScottGNomadI wonder if you have a very poor connection someplace that is causing such a voltage drop that the AC cant get enough current to start.
- MrWizardModeratorwhat about other 110v items, TV, MW, coffee maker ?
do they work
your lights are most likely 12v, they and the water pump and vent fans will run on battery, until the battery is too low
when that happens your fridge might shut off, if it uses 12dc power for control
it sounds like the "transfer switch", this is a relay that auto switches between generator and shore power, the contacts are stuck
let us know what rv you have
somebody can tell you where to look for the BOX that is the ATS "automatic transfer switch"
when you find it smack it good with the flat of your hand, that might unstick it
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 07, 2025
