Bierp's avatar
Bierp
Plumbing - parts and lingo question
I'm definitely a plumbing amateur. I've replaced a toilet and two faucets in my home, but nothing more complicated.
Now I'm trying to install a bidet on to my Dometic 310 toilet. The unit fits nicely, but I'm floundering a bit with the plumbing and I could use a bit of guidance.
First of all, I am really bad with plumbing lingo. The critical piece in my puzzle is the female threaded screw on collar that is at the end of my fresh water line and attaches to my Dometic water valve. What is the name for this part?
Whatever it's called, that's the piece that plays nicely with my water valve. It has a deep open thread area and the 1/2" hose isn't protruding. After several trips to see my helpful hardware man, I'm still struggling to find a connector that gets sufficient grip on my water valve without risking stripping the threads. Home Depot or Lowes will probably have more selection than the local Ace, but I'm all for an RV supply store or Amazon, if I can figure out what it is I'm asking/looking for.
My idea here is to tee off of the incoming water feed. One branch of the tee goes to the toilet water valve, one goes to the bidet. This should be simple, but I'm continually confounded by connectors that don't work as well as the one pictured.
I've pondered cutting the incoming hose, using the existing adapter on the valve and using barb connectors for the rest, but with my low plumbing skill set, I foresee disaster in this direction. If I ended up having to replace the incoming water lead...well, I don't know how to access the main line and I'm fairly certain that's beyond my ability.
If I can acquire another connector (even better with a male end on the other side of a short hose), I can finish this project before our trip in two weeks.
Any help here would be great, thanks.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
