Vintage465's avatar
Nov 29, 2018
Polishing up my Solar System
So I currently have 300w(2 each 150w panels), a Samlex 30a Controller. It feeds 4ea. 6v batteries in series and paralleled. My rig came prewired for Solar. It has the Samlex panels and the Samlex wiring from the panels to the controller. Then the pre-wire from the controller to the battery is 8ga. Probably about ten feet from the controller to the battery. So my plan is to add one more panel and add an MPPT controller. Thinking I will move the controller closer to the batteries, say with in 5 feet and use 6ga. wire. I will rearrange the layout of the 2 panels that are there to allow room for the new panel and the installation of a Fantastic Vent over the bed for ventilation. There is tons of room in the truss area to run wires and with the new hole in the roof for the Fantastic Vent this will ease the wire running too.
So, my questions are:
1. What's the best MPPT Controller out there?
2. When I put the third 150w up on the roof, how do I gather up all the solar output wires from the panels and get them into the controller? Thinking most of the Controllers have one or two input ports for the panels.
3. Are most cables from the panels large enough? Seems to me these are 10ga. from my Samlex panels?
4. Are all panel cables interchangeable? Are there aftermarket cables that are 8ga? Would that be necessary if it were possible?
5. When I move the controller down closer to the battery, the cables that come from the panel to the controller will now be longer. How much will that affect the charging with longer cables from the panels to the controller?
Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
