BFL13's avatar
BFL13
Explorer II
Oct 19, 2015
Poor Man's Trimetric?
I want a cheap sort of 12v battery monitor that can measure at least 100a and keep track of AH. Need some advice here on whether these possibles are any good in the first place, and then about the actual AH counting. I see some of these have a limit on how high they count AH before resetting. I need say 300AH range to show on the minus side as battery bank gets drawn down. Some have AH reset buttons like the Tri.
This one does KWH it seems? Is there a math conversion to AH I can apply?
http://www.ebay.ca/itm/DC-100A-LCD-Voltage-Current-KWh-Watt-Car-Battery-Panel-Power-Monitor-Combo-Meter-/181850187139?hash=item2a571da583:g:lagAAOSwHnFVzsvV
Or for more money, this one says it does AH.
http://www.ebay.ca/itm/DC-120V-100A-Volt-Current-Ah-Power-Combo-Meter-Charge-Discharge-Battery-Monitor-/161152980122?hash=item258577549a:g:5sUAAOxyVPJSJgdk
I have looked at swapping my Tri back and forth between 5er and TC as needed, but is a total PITA. I could ease that by getting just another Tri shunt and some wire and just swap the display unit, but that costs as much as the ebay gizmos. (But at least I would know the Tri does what I want for sure)
Has anyone tried out these sort of monitors or can suggest a better one something like the above two for under $50? (I don't want to build one like Mex would out of a bunch of $1.49 bits and pieces!)
Thanks for any help on this. I don't know how to tell for sure if these or similar are any good or do what I want.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
