- mena661Explorer
Toss in the fact that most RV owners seemingly would rather get an enema than take care of their batteries and you end up with five thousand opinions and billions of dollars spent foolishly on gyro gearloose grade whizzo carnival chargers and devices that swear on a stack of bibles if you pay several hundred dollars you will be forever relieved of ever thinking about your batteries again.
LOL!
More questions for MEX!!! Is it gentler on batteries to equalize at higher volts/less amps than lower volts/more amps? My BD1093 EQ's at 2A but voltages can get as high as 16 (depends on the temperature). My HF charger uses more amps (~8A) but volts are typically in the low 15's. Also, the BD1093 takes longer than the HF. Not sure if that matters.
Another question. A number of battery manufacturers are recommending 15+ volts for finishing charges (basically going from somewhere in the high 90% SOC range to 100%). Based on what I have to do to get mine to 100% SOC, it seems they are correct. Are they correct? - full_moseyExplorer
BFL13 wrote:
It is easy to keep your charger at 10 amps for hours when on a battery? What kind of charger is that?
I don't know!
I do have a portable Schumacher SC1200A 12/8/2A automatic charger with an AGM setting. I guess I would take the battery out of service and run with 8A until it indicated charged. I might let it rest a day and repeat with the 2A setting. Just guessing!
I do routinely use this charger in the AM for bulk catchup until the solar takes over. This is on the bank that runs two 12V Dometic CF-35 portable fridges.
HTH;
John - BFL13Explorer II
mena661 wrote:
BFL, what voltage are you using for a finishing charge?
I use the 1093 15.7v temp corrected at whatever ambient is.
However, on solar this summer, where the controller high point is 14.6v, and after it drops back to float and does that several days in a row, I have seen SG very near baseline, if not there when temp corrected for the warm weather. (I keep not doing temp correction)
So perhaps with shallow cycles like when on solar and low AH usage, they can get close enough to baseline without equalizing so you can't tell the diff. I wonder if it is the deeper cycling like in winter that makes it harder to get back up. - mena661Explorer
BFL13 wrote:
Unless it was a fluke, that seems to be the case with my batteries too. Shallow discharges (like ~85% SOC and above) don't require the high volt finish charge.
So perhaps with shallow cycles like when on solar and low AH usage, they can get close enough to baseline without equalizing so you can't tell the diff. I wonder if it is the deeper cycling like in winter that makes it harder to get back up. - BFL13Explorer III found some interesting Exide stuff I posted in another thread. They might not need or like the rough stuff same as US Battery (among others) recommends for theirs. They don't get into details much though.
- mena661Explorer
BFL13 wrote:
Hmmmmm. Time for me to read some specs more carefully.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
