theoldwizard1's avatar
theoldwizard1
Explorer II
Oct 14, 2018
Portable, battery powered fan
Not a "high tech" question.
I am looking for a battery powered, table top fan, somewhere between about 6" and 12". Not too loud on high speed. It needs to stow fairly flat.
  • Hi rockhillmanor,
    That is one *serious* fan!!!
    My 02cool had an optional power supply. I did not use the batteries at all, except to test the fan out.
  • My first battery operated fans where o2cools too.
    I needed to keep the dogs cool and safe driving thru the south in summer time.
    Unless you have stock in the energizer bunny you will "literally spend $100's of dollars on the batteries" for those fans and they last all of about 15 minutes. And if you use them a lot like I did they just up and die.
    I threw them all out in the dumpster at a CG!
    Here is what I bought to replace them.
    These fans are big, "powerful", low and high speed, RECHARGEABLE batteries AND each charge lasts a loong time. I bought an additional battery kept charged so I can keep these fans running forever.
    Ryobi
    (this pix is from back when I bought them. I think they have redesigned the look of them since then)
    Fan Stands flat or you can hang them up by hook attached to back.
    http://www.homedepot.com/p/Ryobi-ONE-18-Volt-Hybrid-Portable-Fan-Tool-Only-P3320/205022215
    Can't say enough about this portable fan.
  • The red head girl picked up one of the O2cool 10" desk fans at Home Depot for the motorhome. Runs on D-cells or AC adapter. It's compact and quiet. Works very well.
  • 02cool link
    This however is my wife's favorite. She has two one for home and one for travel. Batteries are heavy enough to make it stable ane they last a long time. Her oldest is at least 10 years old and still going great. Thay are variable speed too.
    caframo fans
  • pianotuna wrote:
    02cool makes fans that fit your needs.
    02cool makes one that fits your description except that it is smaller than six inches - and it's enough to stir the air inside an RV bedroom.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
