Horizon170
Jul 22, 2016Explorer
Use one of these. Drill proper size hole. Insert a wire long enough to reach the nozzle hole n run through the valve and pull back into the drilled hole and screw on nut. You may want to use washers that are impervious to Gasoline. Remove all rubber to determine what size hole to drill. Remove CORE and use valve cap Remove cap to pour gasoline.
I've never done it, just thought of an answer. I forgot how to make a HOT link.
Marvin
https://www.etrailer.com/static/images/pics/A/M/AM20906_1000.jpg
Marvin
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
