time2roll
May 31, 2017Nomad
SoundGuy wrote:Maybe we need to know what the definition of start up current is. I assumed it was the start up of an appliance with a high surge requirement.time2roll wrote:
I would still just use bypass mode. Just don't overload the Yamaha trying to run the air conditioner. I see no worry to charge the battery or make coffee.
Bypass doesn't remove the unit entirely from the circuit. Progressive's reason for not using their EMS with the Yamaha EF2000iS has nothing to do with overloading but that this genset's waveform output distorts under certain conditions and it's that distortion that destroys the EMS. I'd remove it to avoid any chance of issues.
Or is it just during the start up of the generator? So give it 20 seconds to get running before you plug in.
Progressive Industries Website wrote:
Yamaha Generator
Please be advised the Yamaha Generator Model EF2000iS does not generate enough start-up current which causes the unit to overload. The generator then puts out non-true Sine Wave power.
