ChooChooMan74
Aug 23, 2016Explorer
You can. I don't think you will have the full 5700 watts, as this is a 240 generator, the power is split between both legs. You will only be using one leg. But, it should still provide enough to run the AC, rather loudly probably.
Here is the adapter you will need.
https://www.amazon.com/Conntek-15872-Generator-Connector-Indicator/dp/B00BHGXUFI
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
