j-d
Aug 23, 2016Explorer II
I hadn't thought you could take two 120VAC circuits, opposite phases, that make up 240, and combine to double the amps at 120. Maybe I'm wrong, electricity isn't high on my expert scale.
BUT I can say this with certainty: If you want to run 15 Amps or more through an Adapter, Do Not Use a PUCK, the $15 one. You need the Dogbone type, with cable between the plug and receptacle, to dissipate heat. The puck will melt and when the rubber melts the contacts lose contact, gets hotter, melts more...
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
