Bobbo
Jul 16, 2017Explorer III
Kayteg1 wrote:
$100 bucks will do it.
They go for $80 with coupons.
https://www.amazon.com/Running-Watts-Cycle-Recreational-Generator/dp/B00O39NQ96
900 watts peak, 700 watts continuous. Totally and completely inadequate.
On a positive note: As long as you only run one high draw item at a time, a 1000 watt generator is adequate. Barely. And the converter/charger counts as one of the high draw items if the batteries are not nearly fully charged. To run two high draw items, a 2000 watt generator. Two high draw items means the converter/charger and one other, like the microwave or the air conditioner. Be absolutely sure that the refrigerator and the water heater are set on propane only. Not on auto.
