CoeyCoey
May 30, 2020Explorer
NRALIFR wrote:
It seems like any generator with remote electric start would work. I’m not sure I’d want to control it with a normally closed solenoid though. Power outages aren’t always a clean off/on event. Most standby generator controls will have some delay built in on both the startup and shutdown process.
If you haven’t already, you might check this product out. It’s intended for the common built in RV gen sets, like the Onan 5500. There’s no reason it couldn’t control a portable generator as well, as long as it’s electric start.
Automatic Generator Start System – The ShorePower Monitor
I don't think I will need one of those. I am simply going to have a relay that closes when shore power is lost and tells the generator to start. Then the ATS will kick over to generator power.
I am going to use a Victron Multiplus as my inverter/charger. The great thing about that unit is it will supplement power to the system when it senses a drop in voltage. So, even though I will have a 2800W generator and the air conditioning needs 3900W for start up, the inverter will supply the extra power for that brief period. This means I would need a soft start device.
