GordonThree
May 30, 2020Explorer
CoeyCoey wrote:
I don't think I will need one of those. I am simply going to have a relay that closes when shore power is lost and tells the generator to start. Then the ATS will kick over to generator power.
A simple relay is not sufficient. you'll likely damage your generator, inverter, air conditioner, etc.
You AT LEAST need a time delay relay, one that for example waits to energize 2 minutes after power is lost, and stays energized at least fifteen - thirty minutes after utility power is restored.
The Magnum AGS isn't very expensive, and likely Victron makes a similar unit for their inverter. Far easier than trying to DIY some sort of time delay circuit.
