Route 66 Traveler wrote:
The both have their advantages and disadvantages. I have seen instances where hard wired units either malfunctioned or had a tremendous surge and came close to catching fire producing a lot of smoke. There is an example on the Jayco forum. It's for that reason I use a portable EMS so if anything goes wrong the smoke and fire potential is on the outside of my RV.
Burned Ems
Yikes.......well not really. That's the only time I have ever read of that happening despite more than a dozen years of hanging around RV boards. When you go through the thread most seemed to think due to a loose lug and not what the OP claimed it was as to the cause, none of which was a tremendous surge or a malfunction. If I was going to worry I would be more concerned about the connections done by the RV manufacturer at the panel/breakers/converter or the lugs on the backside of the shore power connector. I have seen more than a few of those cooked over the years in forum posts where they're left loose right from the factory.
Lantley wrote:
I'm in the hard wired camp. I touched my hardwired unit once. That is the day it was installed. I have not needed to handle it again.
No locks,no storage,no worries.
It alerts me when it needs to. I can check the remote display if I need to.
Otherwise it just does its job without any interaction with me.
Leaving me free to complete my camping goal of just relaxing.
Me too. And if I sell or trade, 15 minutes, a $2.00 J box and a couple of wire nuts, will take care of moving it over to the new rig.
