Powertour's avatar
Powertour
Explorer II
Oct 22, 2019
Portable or Hardwired EMS?
To me it'd be a no-brainer to have a hard wired unit if we were full timers but we're not.
Wondering if it'd make more sense to get an exterior unit considering:
- We're weekenders
- I can see where we might change out rigs sometime within the next 5yrs
Also, I can see benefit in being able to test different pedestals w/out having to move the rig should a fault be found at an initially assigned spot.
Understand a big downside is potential theft of exterior EMS units, just wondering if other than that there's much of a downside to having one.
  • MDKMDK wrote:
    Depending on where your 30A/50A shore power cord is stored, you can plug a portable EMS like the PT-30X into your shore cable, keep the portable inside the (lockable?) electrical bay compartment, and buy a second 30A shore power extension cord, and use that between the electrical bay/EMS and the c/g power post. Cheaper to lose an extension cord than the EMS. It's how I do it.
    If your portable ever fails for any reason, and you're under warranty, it's easier to send it back, than unistalling the hard wired versions or trying to replace parts in it.
    Brilliant!
    - We're weekenders
    Not sure about "more" protection from hard wired units. Dubious?
  • I secure mine with a heavy chain and a good lock. They would have to come prepared and/or destroy the pedestal to walk off with it.
    You can use it to test before pulling into a site or you can test with a less expensive tool. Mine partially failed under warranty and
    was repaired and returned in under a week. Hard wired maybe convenient but its not for me.
