JtTribe's avatar
JtTribe
Portable Solar Generators
Anyone have any exsperience with solar Generators? I'm currently putting the EBL 1000watt voyager and 100watt apollo solar panel through its paces. So far so good! I spend most of my time overlanding in my Jeep. I have been able to do alot more boondocking! I will report back soon!
Have a blessed day! Stay Outdoors!
  • pianotuna wrote:
    Roll your own is far far far less expensive. I'd use sio2 batteries as weight is not a consideration for a class c.
    Absolutely the way to go IMO. I've not considered doing it as it doesn't serve my needs versus the cost. But installing Lithium batteries, solar panels, and an inverter is a lot more cost effective. IMO anyway.
  • Roll your own is far far far less expensive. I'd use sio2 batteries as weight is not a consideration for a class c.
  • I don't have any experience with the Jackery/Bluetti/EcoFlow/etc. units. I have, however, built my own. Two, in fact. Both work exactly as designed.
    The first one I built used AGM batteries, and thus was too heavy to take boon docking but it has proven great for those all-too-frequent power outages at the sticks-n-bricks. The second one uses a LiFePO4 battery, thus is much lighter, and will go camping with us in future. The lithium one with it's 500 watts of solar panels and the folding hand truck weighs just about 100 lbs, and provides 300 Ah and 2200 watts continuous AC power. With that much capacity, I don't even care if it rains for a couple days in a row.
    As long as you sized your unit correctly, you should expect to be well served.
  • If you could mount a solar panel on your Jeep’s roof you could charge as you overland drive.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
