AStinker-
Mar 14, 2014Explorer
Almot wrote:
The heavier of B and C also has 10% larger area. Which simply means - less efficient per sq.ft. Though, being not 10% but the whole 50% heavier, it most likely means - better frame and/or thicker glass. A stronger product, in other words.
It is interesting that they put Cu.inches in the specs - to me this number is non-informative.
Isc doesn't mean much, with MPPT controller. With PWM - yes, it does.
Btw, I will never understand why somebody would NOT want a solar, at today's prices. Bolt 200-300w to the roof and forget about it. It may or may not be the only or the main source of power depending on your situation, but there is no loss here. It will be charging your batteries in between (and sometimes - instead of) generator runs. Though, 100w is more a supplementary energy source, not something to rely on.
Sorry, the Cu. inches was not in the specs but a calculation I had in my notes trying to understand the weight differences.
A supplementary energy source is what I am looking at short term. Actually I am considering 2 of the 75 watt panels and connecting them directly to my batteries without a controller as my energy usage will be greater than 150 watts of panel can generate.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
