NinerBikes
Mar 16, 2014Explorer
vermilye wrote:
You might want to consider some of the folding panels available from Solar Blvd. They include a PWM controller, cable, etc. I have their 160 watt panel @ $239.00 & have been pleased with the performance (although the weight listed on their specifications is wrong - it is around 30 lbs)
Cheap imports from China, but far less expensive than most of the folding panel kits from other manufacturers.
The weight in their specifications is in Kg, not in pounds. Multiply by 2.2 to get approximate weight in pounds.
I have their 120 watt version, and was amazed yesterday, and it's not even spring yet, to be getting a measured 7.04 Amps out of that 120 watt mono crystal panel on March 15th.
This was Oct 25th, 2013.This was March 15th, 2014.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
