csg11's avatar
csg11
Portable Solar Panels connection ?
I need some expertise on connecting two solar panels. I just bought two portable panels with a controller on the back of one. They are connected together like the top drawing with both Positives wires and both Negative wires attached to their respective terminals on the controller. It has about 10' of wire and battery clips for the output to the battery. Nothing attached to the Load terminals.
When I tested the output of the Controller I got 20.1v in full sun. The seller also included another controller new in the box. He had not used any of it nor was there any documentation.
So my questions are: are the two scenarios in the picture the same? I have not had enough sunlight to experiment (sitting in Tennessee waiting for the rain to pass through) and probably won't for a few more days. If the connection is correct, do I use the second controller to limit the voltage to my batteries? Or, will the controller drop the output once it is attached to the 12v batteries (I have not tried to hook them up yet). Or do I disconnect them and wire them like the bottom half of the picture?
Image of the controller on the panels.
Thanks for any help.
  • The top drawing is better. You only need the one controller. Never mind the load terminals--ignore them.
    You could use the second controller and have one panel for each controller. You can then put both controllers on one battery bank or have one solar set for each bank if you have two separate banks.
    The 20v you got was the Voc at the time. Looks good. When on the battery, the panel voltage will be near the battery's voltage when the controller is in Bulk and then go up during the Absorption stage.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
