ppine
Feb 29, 2020Explorer III
Connect to one battery that are usually wired in parallel. I have 2 panels that are 100w each. I have a 40 amp controller in case we want to go to 400 watts. Having portable panels works well. You can adjust the angle. The problem is that leaving them on the ground when you are not there invites theft. I will probably put them on the roof eventually.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
