- Old-BiscuitExplorer IIINegative shuts off ALL loads.
Positive, depending on where installed, can still have parasitic loads (LP detector, radio/stereo) and tongue/landing gear can still be powered)
SO........
Put it where it works for you. - TlaudenExplorerPositive, that way there is nothing hot anywhere in case of accidental grounding...
- TeetonExplorerHoly crap!!!Put one on both all ready.. :)
- AlmotExplorer III
smkettner wrote:
An exposed switch such as a knife style I would put on the negative. Especially if in a metal box.
Didn't think anybody is still using this type of switch, but - yes, this would be the only scenario when it's better on Neg. - AlmotExplorer IIIdp
- SCVJeffExplorer2PST
- fla-gypsyExplorerMy battery disconnect switch instructed me to place it on the negative side. As far as the the political side of positive and negative, some of you could use some "shock" therapy.
- beemerphile1ExplorerMH - doesn't matter
Trailer - positive and the breakaway is wired prior to the disconnect. - Houston_RemodelExplorerOurs is on the negative side as that is where the electrons leave the battery.
The trailer box is dead, the hitch and break away switch still work.
Most importantly the hitch light will NOT work so people can't leave it running by accident or on purpose to drain the battery. - D_E_BishopExplorerIt looks like this has pretty well played it's self out, however, I have a question. I have looked for a description of a Torx box without luck. Being that the discussion is about a TH and I'm more familiar with MoHo's, I kindda figure it has to do with towed RV's rather than powered RV's. Anyway, searches provided nothing but ads for TOXR wrenches.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
