buzzard616's avatar
buzzard616
Possible hub failure
Two years ago the right rear hub on the signature TT sheared off just inside the outer bearing after being cool to the touch at a stop 45 min earlier. Failure occurred on a hair-pin turn entering the campground so no further damage was done.
Yesterday while checking tire/hub temps at a stop I found the right front dust cap rolling around in the wheel cover. I cleaned it out and tapped it firmly home only to find it loose again 20 min later.
Has this happened to anyone else? I've never had a dust cap fall off anything before! Is there something I need to know about 2000 ALKO hubs? We bought this TT in 2011 with 75 miles on it. It was on a permanent lot for its first 10 years so the running gear is not exactly 'high mileage'.
Hopefully,
Stu
