Finder9
Aug 18, 2013Explorer
Hub and Wheel Failure on Trip
Will try to keep this short. Friend of mine towing a 2009 Aliner has had TWO hub and wheel failures while on an extended trip. The second failure has occurred in Newfoundland. From what I can extract from abbreviated conversations is that excessive heat has caused the lubrication in the hub to evaporate causing bearings to fail, hub to seize, and expensive repairs to follow. This happened AGAIN today.
Only this time the wheel actually broke (aluminum I think)and the axle sustained damage. I have never heard of this occurring in 25 years of rv'ing.
To me, heat is generated by friction. But friction from what? Brake pads? Failed or improperly installed brake controller? Too much voltage to brakes?
Any and all comments appreciated. It's a sad situation he's in.
Thanks.
Thanks.
