buzzard616's avatar
buzzard616
Possible hub failure
Two years ago the right rear hub on the signature TT sheared off just inside the outer bearing after being cool to the touch at a stop 45 min earlier. Failure occurred on a hair-pin turn entering the campground so no further damage was done.
Yesterday while checking tire/hub temps at a stop I found the right front dust cap rolling around in the wheel cover. I cleaned it out and tapped it firmly home only to find it loose again 20 min later.
Has this happened to anyone else? I've never had a dust cap fall off anything before! Is there something I need to know about 2000 ALKO hubs? We bought this TT in 2011 with 75 miles on it. It was on a permanent lot for its first 10 years so the running gear is not exactly 'high mileage'.
Hopefully,
Stu
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
