dennislanier's avatar
dennislanier
Power awning question
I have a 2004 Jayco Motorhome with a Carefree One Touch power awning. It has been working intermittently the last few times I used it. It sometimes will fully extend and retract, at other times it will go part way in or out then stop. I let it rest a little while and then it works again. My main question is, will a bad motor work intermittently? I am quite sure it is not the battery or the switch. The reason I say this is because I used a jumper wire hooked to the motor and the chassis battery, and it did the same thing.
I have checked the rails and there is no obvious binding or anything else I can think of. I will replace the motor if necessary, but does it make sense that the motor would work "part time" or not? Any suggestions appreciated.
  • dougrainer wrote:
    IF you connected to the emergency pins at the motor and it did the same thing, then yes, the motor is bad. Yes, motors can operate Intermittantly. You can have a dead spot in the windings. Doug
    Thanks Doug. I kinda figured that but wasn't sure about the "part time" motor. Guess now I get to do some research about replacing the motor. Thanks for the info.
  • OK See that you did the right thing and eliminated everything but the motor and the mechanism.
  • Monaco and CareLess used 14 gauge wiring to my awning and CareLess uses 16 gauge on their relay. The result was 8.5V to the the CareLess motor when retracting. I replaced the wiring to the switch and now have 11.5V and it works as it should. I still have the 14 and 16 gauge wiring from the switch to the motor.
  • IF you connected to the emergency pins at the motor and it did the same thing, then yes, the motor is bad. Yes, motors can operate Intermittantly. You can have a dead spot in the windings. Doug
  • MFL wrote:
    I am thinking it may have a reset switch, for overload, that is getting weaker. After a short time, it resets, and finishes the job.
    You could try to contact Carefree and ask them.
    Jerry
    Not unless it is built into the motor itself, because the jumper wires I made bypasses everything else. The jumper runs from the truck battery straight to the motor.
    I may try calling Carefree as you suggested to see if they can help. I know they no longer make the OneTouch so I may be out of luck. Thanks for your response.
  • I am thinking it may have a reset switch, for overload, that is getting weaker. After a short time, it resets, and finishes the job.
    Jerry
