powderman426
Feb 14, 2015Explorer
This may not be the right thing to do, but I would repair the damaged wires as stated above, check the voltage at the post, then trip off all the breakers. Then plug it back in and if all seems OK then turn on each breaker One at a time while monitoring what is happening. It may also be a good idea to replace the load center.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
