DrewE
Feb 14, 2015Explorer III
smkettner wrote:
Seems odd to have them all burned. Lose or dirty connection causes the heat. Almost looks like some arching on the plug may have exasperated marginal connection on the neutral bus. But what was drawing so much power? Not that it takes a whole lot. Is the battery OK?
Arcing at the plug wouldn't affect the neutral bus at the power center in the camper; it would only result in lower current draw. The wires are all toasted because the heat from the bad connection was conducted across the neutral bus and made them all get hot.
Robbystone: I strongly recommend that you replace the neutral bus bar, rather than reusing the old one. Once it's gotten so hot, all bets are off as to whether it will still clamp and make contact properly. Replacement bus bars are readily available at electrical supply places (and probably home improvement stores) and are pretty inexpensive, doubly so when compared with the costs involved with having an RV burn.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
