westend
Sep 14, 2015Explorer
Ductape wrote:Perch or Grouper, sometimes relevance aids....
Re Mex; Depends on whether we are asking for their preference in fish or showing how fish are caught.
First thing noted is that you have group 24 batteries and one is failing/failed. I wouldn't bother replacing with the same. Group 24, especially a Marine Hybrid. It is way down the pecking order in capacity for anyone going off-grid. The best bang-for-the-buck I've found is 2 X 6V GC2's from Sam's Club or Costco. I bought a pair two years ago for $190 out the door with tax and core charge included. Pricing remains similar. That will give you 205-240 amp hours of capacity, a good amount for an RV'er with typical power needs. If you invert the 12 V to 120 V (very useful) and have a wife that needs to use hair dryers, curling irons, and brews coffee through a Keurig, you will need even more capacity.
I use solar for 99% of my battery charging. I also invert to 120V for running a 120 V fridge and entertainment devices (TV, stereo, disc players). Solar does a better job of charging my batteries then I can, manually. I believe it's also better than any converter/charger.
I still have the original Progressive Dynamics PD-708 30 amp converter in the rig. The adder circuit board charger-modification tells me that the 708 is at least 44 yrs. old. If I was buying another, it would be from Progressive.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 30, 2026
