D_MAX
Jun 19, 2020Explorer
2oldman wrote:D MAX wrote:I need clarification on this.
On DC (2 x 6V) lights are good, power shows full (also metered at batteries 13ish). When the water pump kicks on it dramatically slows down,....Checked the voltage at the batteries while this happens and it shows a slight drop. On shore power no problems at all.
"On DC". Does that mean on batteries alone without the converter running? 13ish is not the resting voltage of any battery, so it sounds as if the converter is on, but then later you say..
"On shore power..." (which runs the converter).
thanks
Ya sorry that may have been confusing. On DC was just running off of the batteries. I metered them after all this started, and had been running lights, fans and the pump several times to troubleshoot. I can’t recall if it was 13.2 or 13.4. Should also note I have a solar panel.
When on shore power there are no issues.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
